i am unrooting because my phonesheadphone jack is messedup and i need to take it to the metro store. i need a stock ZVD bloated just like normal.
wow... just kill me alreadyThe only way you could go about doing this is to first downgrade to ZVB and Re-Update to ZVD.
DOWNGRADE TO ZVB
http://androidforums.com/esteem-all-things-root/479734-guide-downgrade-ms910zvc-ms910zvb.html
RE-UPDATE TO ZVD
http://androidforums.com/esteem-all-things-root/512317-guide-x2-update-zvd-root-zvd.html
it says ZVC to ZVB im on ZVD.. will it work?The only way you could go about doing this is to first downgrade to ZVB and Re-Update to ZVD.
DOWNGRADE TO ZVB
RE-UPDATE TO ZVD
:thumbup:it says ZVC to ZVB im on ZVD.. will it work?
If ya get stuck just post up in one of the threads or here.
When you downgrade to ZVB is will be in it's full bloated glory
Could just return it that way as it will not be root![]()
haha thanks!!!! i got it just have to update hopefully nothing goes wrong thanks guys for the help you all are the best![]()
