kilasix9
Ok so after rooting my device and installing Gingerblur, things were running smoothly for about a week. However, I started noticing the phone having some issues. Most noticeable the Car Dock doesn't work correctly with the music app. I was also noticing some issues with performance. All in all, I became tired with the whole idea and decided I'd go back to stock.
So since I used Gingerbreak to root, I ran the app and hit the unroot option. I figured this would unroot my device back to stock. Along with unrooting I figured the Gingerblur ROM would be removed since it requires root. WRONG. So I made the mistake of doing a factory reset, thinking it would resolve my issue. WRONG AGAIN.
My phone has apparently been unrooted as I ran Titanium Backup and it says unrooted cannot verify. But Gingerblur is still on there. Then when I hit my home button, it gives me the option of accessing the launcher which takes me to gingerblur home screen or setup which takes me through the stock initial setup.
The cellular radio wont work and it keeps giving me on error on the startup. Basically I'm stuck on one side with the stock setup or a Gingerblur homescreen with no data or voice access.
How can I undo all of this? I just want to go back to stock, out of the box setup. I don't care about losing data as everything is backed up.
Please help!
Please help!
