Won't turn on at all? Perhaps it's just the battery that's dead and won't even charge at all. This phone is from 2004 I think, battery is probably well shot. If it is the battery, might be worth trying another one...they're still available apparently.
https://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias=aps&field-keywords=k700i+battery
Anyway,as it seems I won't get answer to this question so I'll use the opportunity to ask You:
I would like that my CM 13 touch sound sounds like the one on stock Samsung Touchwiz.Is there a way I can set that ?
Thanks
Yes,tried,obviously battery problem.Have you tried putting the phone on a charger to see if you can get it to boot?
Thank You very much !With a root enabled file explorer go to /system/media/audio/ui .ogg are audio files. You will need to test till you find the correct one. replace with desired tone. This MUST HAVE THE SAME NAME AND PERMISSIONS AS EXISTING, usually the permissions are rw-r-r.
