Upate Help
Cthomas5
I recently bought a Motorola Defy on 2.1 of a friend already rooted but i want to update to 2.2 Froyo however when i try to update from the phone it never finds the update and when i went to the motorola website to download the updates, it said it checks the warrenty of the product so im very hesitant to try and upgrade from there, as im guessing rooting it voids the warrenty.
Is there a way to upgrade to 2.2 without unrooting my phone
p.s (this is my first ever android phone so i dont have alot of knowledge about them)
Thanks
Where in the world are you and what network are you on?
Motorola are currently rolling out 2.2 worldwide. For example, T-Mobile in the US had the update a month or two back, but those on T-Mobile in the UK will not get it till next month.
When it is available in your region, you should get a message sent direct to your phone.
You can also check yourself >Menu > Settings >About Phone> System Updates
There is a Motorola support forum that lists when the changes are happening. As you only have 2.1 I'm guessing you are not in the US, so the correct link is...
https://supportforums.motorola.com/message/409962#409962
You can also download updates from the support area on the Motorola website.
Ok thank you and i live in the UK and im on 02
On the official website it says that when you update, it checks the warrenty of the phone and since mine is rooted wont that void the warrenty.
I have recently found that some people use ROM's to put updates on their phone is this an option i could use if so how do i do this
Hi
i updated to 2.2 on a rooted defy and im on o2 too - its fine! :)
Sean
