Root [Update Decommissioned][ROM/THEME][WIP]Red and black stock deodexed
Status
Not open for further replies.
marc12868
Android Expert
This is my first theme/rom. It will be red and black throughout. If you like it then give me a thanks.
This is based off of JKILO's stock deodexed rom. It is prerooted.
I will upload flashable zips for it probably fairly often until it is fully themed.
PREREQUISITES
  • Have s-off
  • Have Clockworkmod recovery installed
TO INSTALL
  • Download the rom and put it on your sdcard (anywhere is fine, but the root of the sdcard makes it easier to find. The root of the sdcard is the area that opens when you first open your sdcard.
  • Power completely off and make sure fastboot is off (settings> Power> Fast Boot needs to be unchecked! Important)
  • Now hold the volume down and Power button
  • You will be in the hboot menu[/INDENT]
  • Scroll to "recovery" you will now reboot into Clockworkmod recovery
  • Make a nandroid backup!*
  • Scroll to "wipe data/ factory reset" and select and select yes **(this will erase your current rom and all apps and data so if you don't want to lose that I recommend making a nandroid backup.)
  • Scroll to "install zip from sdcard" and select
  • Choose "choose zip from sdcard"
  • Now scroll to the .zip that you downloaded and put on your sdcard and select it and it will install
  • Now reboot your phone
You now have a themed stock deodexed rom! :D
* A nandroid backup isn't required, but is helpful if you don't like this rom and want to return to your previous set-up just the way that it was.
**You might not have to do a factory reset if you are coming from the stock or stock deodexed rom. I'm not 100% sure on that so best to do a factory reset just to be safe.
DOWNLOADS
V.0.3:
http://dl.dropbox.com/u/65981188/Red_and_Black_themed_rom_V.0.3.zip
Changelog:
V.0.3: A lot of messaging app themed and the com.htc.resource which is a lot of the icons all around the rom. Music app partially themed. A lot of random stuff is partially themed. Lockscreen isn't fully themed for some reason I will try to get that fixed for the next build
V.0.2: Second release. Calculator and lockscreen are fully themed including text colors.
V.0.1: First release only calculator and partial lockscreen themed.
Pics:
Lockscreen:
Calculator:
Credit:
JKILO: Giving me permission to use his stock deodexed and rooted rom to base everything from
Ziggy46: Helping me to learn some theming/ Changing xml text color for me
Yeahha: Has given me helpful info on theming
Anyone else who I forgot to mention.
I have the calculator and lockscreen completely themed including text so I will upload a build with them. That way it's more current. I'm having a bit of issues with the music player, but hopefully can get that figured out and themed.
Yea :D. And know that I only work 5 days over the next couple weeks I'll have plenty of time to work on theming some more stuff :D
Awesome, I will have to check it out this weekend!
Sent from my Bulletproof_Doubleshot using Tapatalk 2 Beta-4
Cool. I'll have a new version up today probably, just have to get it working... When you test it out let me know what you think please :D
I don't know that anyone is following progress on this, but just wanted to say that I haven't made an update in a while, but I should have another update up in the next couple of days. :D
This is just an update to let people know I am no longer working on this. I will keep the download link there so that you can still download it and I don't care if you want to work on it your self more, but if you do please give credit where it is do. Also if anyone needs any help with anything I may be able to help :).
Status
