Help Update Eclair to Froyo while running Voodoo lagfix?
bnas
Is it possible to run the Keis firmware update to Froyo if my Galaxy S running Eclair has the Voodoo Lagfix? I have a reboot app that let's me reboot with or without the lagfix. I could reboot without it, then update. Would I still need Voodoo after Froyo update?
Thanks.
You have to disable lagfix first. Make sure to uninstall it because it might cause your phone to brick. After update you can reinstall it but I don't think you need.
