agentc13
Daleks Über Alles
Bug fixing update headed to T-Mobile’s HTC One S tomorrow
From T-Mobile:
From T-Mobile:
Understanding the Update
Beginning May 31, the HTC One S will begin receiving notifications for software updates. The latest software build will improve software stability and resolve open issues with the device. The new software version is 1.84.531.2 710RD. This update will continue until June 30.
You can update in two ways:
Over the air (OTA) update: T-Mobile will push the update to your device sometime between 6/4 and 7/7. We cannot expedite how soon we send the OTA to individuals.
Manual download: If you do not want to wait for the OTA, you can update immediately through the settings menu. See the steps for Download update from HTC below.
Current Software Version & Update Status
1.84.531.2 710RD - This software version is current. Your device software is up to date.
1.53.531.16 710RD - Beginning May 31, follow the steps above to Download update from HTC.
Other versions - T-Mobile and HTC will not send you a software update. Devices with non-T-Mobile software versions are out of warranty and do not receive updates.
Software versions
See also: Check your software version.
- Android version 4.0.3 / Software version 84.531.2 710RD - Current version
- Version
- Android version 4.0.3 / Software version 1.84.531.2 710RD
- Updated 6/41/2012
- Improvements
- Resolves goodbye splash not appearing when powering off due to low battery.
- Resolves voicemail indicator not appearing while using Wi-Fi calling.
- Improvements to Wi-Fi Calling
- Improvements to camera stability
- Resolves signal fluctuation.
- Prerequisites
- OTA update
- Device is running Android version 4.0.3 / Software version 1.53.531.76 710RD
- Device software is not rooted
- More than 50% battery life
- Data connection
- 350 MB available memory (File size of update is 24.2 MB)
- Android version 4.0.3 / Software version 1.53.531.16 710RD
Help & How to
You may request the update from the update servers, even if you have not received the Over the Air (OTA) update. To download or check for updates, follow these steps:
- From the Home screen, press the Application key.
- Touch Settings.
- Touch About phone.
- Touch Software updates.
- Touch Check now.
- Follow the on-screen prompts.
- Wait as your phone restarts and updates to Android 4.0.3 / Software version 1.84.531.2 710RD.
Download Over the Air (OTA) software update
After receiving a notification that you received the OTA update, you may download it. To download, follow these steps:
- You will receive this notification message when the update is available for you:
"This software update includes new enhancements for you HTC One S. It won’t delete any of your content, but you will be unable to use your device or make emergency calls for the duration of the install. The update is expected to take 10 to 15 minutes, but could take longer."
- From the message Notification Screen, touch Download.
- Touch Install Now.
