odatkid
Hi all,
Just did a Nand restore after not being able to boot into cm7 (got stuck at boot-up animation for some unknown reason). I chose "nand restore" and it completed and then I chose "nand backup" to be safe and not sure what to do next. Do I choose "restore Google proprietary sys?
Stuck at that screen. Need help ASAP.
UPDATE: I think I figured it out and did the nand restore (very cool btw..thank you all) I did not do "restore Google proprietary sys".
I then reflashed the cm7 rom booted and then flashed the MM fix. Feeling my way around the phone now. Any tips greatly appreciated.
Thanks......Tom
Thanks......Tom
