Update Tool - massive driver problems
Hello,
I tried to use the Update Tool and went through the entire installation throwing several drivers at me that I ALL installed.
I think 4 drivers or even 5 were installed, didn't get one error message.
After driver installation I reboot my PC, start up the Update Tool and connect my phone to the included USB cable with the PC.
Only 3 (if even that many) drivers recognize the phone. 5 other drivers giving me errors. The phone is not recognized in the Update tool.
What can I do? I did this on two different PC, both the same results. I can't even access the SD card of the phone.
Thanks in advance.
Did you install the USB drivers for your phone? Click on the 'Install USB drivers' in LGMobile Support Tool and select your phone.
Yes I did that (multiple times)
I installed any USB driver I could for this phone.
I tried it on 2 different computers, same result - it won't recognize the phone.
I deactivated Kaspersky internet security - no success either.
No idea what else to do.
