wetbiker7
Extreme Android User
UPDATED 3-18-13
PARANOID ANDROID HAS BEEN UPDATED TO V3.10 AND ONGOING DEVELOPMENT IS LOCATED HERE:
http://forum.xda-developers.com/showthread.php?t=2057596
THE VERSION 2.54 POSTED HERE IS STABLE SO I WILL LEAVE IT UP IN CASE ANYONE WANTS TO USE IT. IT'S A VERY NICE AND HAS FULL KEYBOARD FUNCTIONALITY.
VERSION 3.10 LOCATED AT THE LINK ABOVE IS BASED OFF THE NEWEST JELLY BEAN BUILD AND HAS FULLY WORKING PIE. IF YOU WOULD LIKE TO TRY IT OR FOLLOW IT'S PROGRESS, PLEASE VISIT KEEGANMCCALLUM'S THREAD.
_____________________________________________________
HI All. I wanted to bring this great ROM to Android Forums. Please read the first 3 post as they contain important information for you.
There is a modified Untermensch kernel for this ROM that allows overclocking located under EXTRAS in the 3rd post.
Thanks go out to KeeganMccallum for porting this awesome ROM to our device and giving me permission to share it here. Enjoy!!
Thanks, Wetbiker7
[Update][NOV.12.2012][ROM]PARANOIDANDROID 2.54 [HybridMode, Per App Size & UI/Color]
It's More than Tablet/Phablet Mode or Build Prop Tweaks
PER-APP-DPI/LAYOUT. This is not tablet mode! Hybrid engine allows you to target apps individually. You get to pick their actual layouts which can tranform content drastically. Keep in mind, this has nothing to do with build.prop hacks or DPI changes. We list all layouts an app brings, you choose one, its as easy as that. It does not matter if your device runs itself in Phone-, Phablet or Tablet-UI, your apps will always look as you like. On top of that you can scale apps, to fit your screen, that way you can even bring full fledged tablet apps and make them run perfectly. Nothing will break, nothing will shrink, your market will be fine. Additionally we have rewritten many parts of the android framework and fixed countless of AOSP bugs to make way for these modifications - our "tablet mode" runs better on a phone than on a real tablet, that is guaranteed.
PER-APP-COLOR, Paranoidandroids newest invention. Define apps in your regular hybrid panel. See your phone fade into the color definition of your current app, press home or go elsewhere and it fades back. Create as many combinations you like, you can even dabble with opacity. This feature is made possible by our hybrid engine, which is unique to this rom.
If you like my work,please press thanks, or donate to a starving university student
Thanks, Wetbiker7
- FOR JB BOOTLOADER ONLY!
- Make sure you have a stable recovery installed, i recommend TWRP, if you must, CWM
- Let it make a full backup, should anything happen you'll be safe, IF UPDATING BACKUP PREFS FROM PAPREFS!
- RECOVERY: FACTORY RESET IF YOU WERE USING ANOTHER ROM!
- RECOVERY: Install Rom: https://docs.google.com/open?id=0ByV...UdIdndaUVVBdjQ
- RECOVERY: Install Gapps, ALWAYS-EVEN FOR UPDATES: Download (find the latest one that carries the "jb" tag)
- RECOVERY: Wipe Cache Partition
- RECOVERY: Wipe Dalvik Cache
- Reboot and enjoy
- Paranoid's webpage: Paranoid Android - Home
- Complete guide to ParanoidPreferences: http://forum.xda-developers.com/show....php?t=1927208
- Get PA synced to your dropbox folder automatically, apply here: http://forum.xda-developers.com/show....php?t=1820276
- Themes and other goodies you can find here: http://forum.xda-developers.com/show....php?t=1646034
- If you have an issue and you want to call our attention, here's what you do:
- 1. Try everything you can, find solutions for yourself. Wipe caches, revert all your settings you have made, go back to your stock Kernel, factory reset if you have to or reflash the rom. Assume that the issue is on your side and try your best to isolate it.
- 2. Search this thread and Cyanogenmods aswell (its our base) for possible reoccurences of your issue and hopefully solutions that may have come up.
- 3. If you think the issue is important enough that we should cease our work and look into it, post your issue, BUT ...
- ... stay friendly, do not demand anything, do not threaten
- ... explain your issue as precise as you can, name the exact apps and conditions that cause trouble, help us to replicate the issue right away. If we can't there's no way we can fix it and your post will simply clutter the thread
- ... collect evidence, keep in mind this is a developer thread so even if you are not one, do us the favor and research how to record logcat. logcat is the single most important help you can give us to resolve your issue.
- Tina: KREBSMILK
- Cyanogenmod Team
- AOKP
- jaybob413 for his work on the TF700t Paranoid project, helped alot
- Google Android Open Source Project
- Asus for kernel sources and jellybean firmware
- TeamWin for the TWRP recovery
- XpLoDWilD and untermensch for bringing CM10 to the JB Bootloader
- Molesarecoming since I mostly quoted his post to use for mine
- The entire Paranoid Android team and website community which has been extremely helpful
- the xda community, they have taught me everything I know about android and porting ROMs
- probably missing some, please just point them out to me and I'm happy to include anyone I have borrowed from
Donations to molesarecoming
to D4rKn3sSyS
to Cyanogenmod
