Updated install guides for everything
King_bob
Member
Hi again,
after reinstalling my firmware accedently (dont leave the image folder in your sdcard) I decided it was time to update my installation guide.
LePhone Page
it now also hast screenshots of all the new firmwares including the gingerbread native 2.3 version
I am missing a link here and there and screenshots of older versions, so if anyone has any of that Ill add it. Hope this helps
EDIT: I also added a forum just for the fun of it... feed back can be added there
EDIT: There are 3 new firmware versions from allPhone listed with download link and screen shots on the site. (Im actually using the Cool Blue custom version as of now since it gets rid of the clover with out getting rid of it, and allows the alt tab function, I jus dont like the blueness of it all ^^, so somebody find out how to work the skineditor so I can go back to black :) )
Great work...
although there are also the IT168 nova 1.0.5fix2 roms for all varient lephones vanilla gingerbread 2.3.2 (which I use) and doesnt have so many problems. Worth adding to the list :o)
I saw that, but I wasnt event sure that it was different than the ginger bread native ...
downloading it right now....
before i install it can anyone tell me if it has an alt tab function like the LeOS versions?
and does it look any diffrent from the gingerbread native release?
It's different as there are versions for all three varients of Lephone.. I use the 3GW101 and the plain Vanilla android you have on your site isn't available for my varient. The Fix2 apparently sorts out a few issues... The only real issue I have is that the brightness resets to dim upon wake - but I put up with this to have a far more usable and Android / Google compatible phone. I've used it for a few weeks now and won't be going back to LeOS... but i will be keeping my eye out for further improvements they make. If they iron out the brightness issue, I would be 100% happy. No alt-tab function but I swipe to the right and it takes me back to the home screen while keeping an app open.
IT168 nova 1.0.5fix2 should be IT168 Nova Gingerbread firmware: (Password lephone.it168.com) (Android 2.3.2 Based) ?
