Root *UPDATED* [THEME] Blue Mix by BlazingFire258
BlazingFire258
UPDATED!
Fixed colors for better icon display in notification bar. (Thanks to istos)
Changed Lockscreen sliders to all black
Changed pattern to android instead of smileys
This is the first theme I've ever made but I did my very best to make this theme look good. I personally use it so if there is any issue then leave a comment.
I've personally added instructions on how to apply the them.
Quick Description:
Has ICS transitions. Blue was the main color used. Changed the default lockscreen sliders. And security patterns are android logos :P.
Files you'll need:
framework.apk - Dev-Host - framework-res.apk - The Ultimate Free File Hosting / File Sharing Service
systemUI.apl - Dev-Host - SystemUI.apk - The Ultimate Free File Hosting / File Sharing Service
README.txt (Instructions) - Dev-Host - README.txt - The Ultimate Free File Hosting / File Sharing Service
Screen shots below.
This is my first theme ever made but I did my very best to make this theme look good. I personally use it so if there is any issue then leave a comment.
Quick Description:
Has ICS transitions. Blue was the main color used. Changed the default lockscreen sliders. And security patterns are smiley faces now :P.
Files you'll need:
framwork-res.apl - Dev-Host - framework-res.apk - The Ultimate Free File Hosting / File Sharing Service
Screen shots below.
Thanks! It's awesome! Only thing i noticed is that the USB icon is white, so you can't see it when you expand the notifications.
