DashRipRock
Update my Acer Liquid E to Android 2.3.7 it wasn't too bad.
Backed up my phone with Titanium
Removed SD and used a spare.
Installed Malez Recovery
Did 3 Button start to start Malez
Wiped/Formatted the SD ext
Wiped the phone using the Wipe All option
Turned on USB Transfer in Malez
Moved Zipped Liquid Next folder to SD.
Installed Software on phone
Re-Booted
The whole above process is done in Malez Recovery.
Usual start-up stuff google account etc.
You have to download some Liquid Next software to complete the process
Re-installed Titanium
Put Original SD Card back in phone.
Do restore of all apps and data
Reboot
Done.
Everything seems to work.
3 hour after this post the phone became very unstable. Figures. I re-did the above procedure and did a selective restore. The programs I needed when I was running a rooted 2.2 are mostly not needed. The 1.9.2 has everything in it. The phone is running much better using the included software to configure the phone. There are a couple of programs that won't work in 2.3. But nothing critical. Having backups is very important. I have my schedule and contacts backed with Google and my bookmarks backed up with Dolphin Sync. The rest of the stuff is backed up using Titanium. So no worries.
Re-Booted
Reboot
Done.
