That's odd. I suggest you do a factory reset to clear the OS and set up the phone again. It's a bit of a hassle, but it should fix the issue.After OTA Jelly Bean update. Phone re lots randomly during calls.
See if a reset fixes it.I get the same bug. It doesn't just happen during calls. I've had it in ICS too. It doesn't happen very often.
