Help Updating Android
gmchale
Hi
I want to update my android Phone to Android JellyBean. Is it possible in any way? If yes please help
Thanks
It all depends on what device you have. In most cases, you will need a computer, internet connection, syncing cable and software(for computer). This software is dependant on the device. For example, a Samsung has something called Kies, Sony Ericsson has PCCompanion and so on. Also, whether or not the device has an available update to Jellybean is also a question. The older, and therfor less powerful, it is, the less likely this is. Just google and you can easily find a list of phones that are supposed to get the update. Just as easily, you can also find a set of device specific instructions for the procedure.
