updating JVC 32 inch smart tv
djcurzed
Hi Guys,
Not sure if this is the right place to put this.
I have tried updating the firmware on my JVC smart tv, but everytime or every which way I try, it keeps telling me Settings has stop responding etc then exits from it.
Im wondering if anyone knows where I can find the actual firmware, or if there is other firmware i can use, and how to flash this tv.
Please advise.
Regards
Warren
i contacted head office of jvc in Dubai, they said the update button is only for service use, not for android update.
Basically an android update is not possible. it remains as is unfortunately. the bigger sized smart tv's have a more recent version of android
Hi, I am also having the same problem with my JVC 32" smart tv (LT-32N630S), I contacted JVC Jeddah Office and they said android updates for smart tv is not available.
anybody found the solution for it, Please share.
vvkabir@hotmail.com
Hi Guys,
Please advise.
Regards
Warren
Hi..did you found any solution for this?
If any other poor sods bought this tv and are experiencing stuck on logo while booting or 20 minute boot up times, I have the knowledge and the firmware to fix it. Let me know.
Note that the firmware is quite likely 'localised' so installing one intended for a different regional market may result in further issues. Just something to be aware of.
Hi,
My new JVC tv struck in the "JVC logo" after power ON and it is hangs there only.
I just see your post in this forum , Can you please help in solving this.
guys I m from Dubai.. I have lt32n630s.. 32inch smart tv.. it got stuck in smart tv logo.. its not going further.. any solutions please..
Multiple users reporting the same problem with this JVC TV, in that it's not booting, possibly corrupted firmware, and likely needs to be re-flashed. Think you'll need to contact JVC tech support about it, find what's needed and if they make the required firmware files available.
