Inception_Bwah
I'm trying to update my Sony Xperia L from Android 4.2.2 to 5.1.1. I've been following the instructions on this page here :
http://www.android.gs/update-sony-xperia-l-to-android-5-1-1-lollipop-with-unofficial-cm-12-1-rom/
It was all going fine until it asked me to boot into recovery mode. I couldn't seem to do this manually so I used Recovery Reboot and then there were 5 options:
reboot system now
apply update from ADB
wipe data/factory reset
wipe cache partition
enter fastboot mode
Like the instructions said i selected the wipe data/factory reset option and that ran fine (it only took a couple of seconds), however there was and is no advanced options menu option below the fastboot one like it says there should be. how can I fix this so I can do the rest of this?
Thanks
reboot system now
enter fastboot mode
Thanks
