upgrade android
  • Thread starter Thread starter shubham khinchi
  • Start date Start date
Hi and welcome to Android Forums!
Go to Settings --> About Phone -->System Updates and check for an update. If none are available, then you would not be able to upgrade your system without rooting and installing a custom ROM to replace the operating system of the device. Rooting and installing ROMs are great alternatives. I refer you to the All Things Root section of our Micromax A57 Forum:
A57 - All Things Root - Android Forums
Read, understand the process, and ask questions BEFORE starting. Good luck and I hope this helps.
It’s great to have you here :)
