Hi all. My Galaxy S is currently on android 2.3.3 (jvo) and I want to upgrade to 2.3.4 (jvp) using this method in link.XXJVP Android 2.3.4 Firmware for Galaxy S [Download/Install] | TheAndroidSoul
1) Do I need to be rooted to use odin?
2) Does it matter at 2.3.4 version is jvp not jvo as my current version is jvo?
Thanks in advanced
Thanks in advanced
what will you use for backup?
just make sure to backup USER apps and data, NOT SYSTEM apps and data because you can run into some trouble.
