Hermitkrab
My tablet is running android 6.0. Is it possible to upgrade to the latest OS? I'm a Windows person and fairly new to android. Thanks for any help.
i agree mostly with your statement except for the rooting part. if there is a community of devs that is supporting this tablet, then the op is good to go, if rooting is something the op wants to do. if there is no dev community, then that is different. custom roms will vary as far as performance goes. as long as you have a custom recovery, it is very easy to restore back previously or you can just flash another rom to try out. and by the way there is no such thing as a custom firmware.....basically a custom firmware is just a firmware that is rooted with nothing added by the developer.....so it's basically just a custom rom with no bells or whistles.If RCA haven't pushed an update, then there isn't one, it's the same with ALL large manufacturers, they want you to dump you current device and buy a new one that has that upgrade. I have 3 Android devices and neither of them have any updates from the manufacturer, I have an LG Stylo 4 (Android 5), an Onn (Walmart brand) tablet (Android 9), and an RCA Viking Pro (Android 5), and every time I check for an update, it says my device has the latest firmware.
Oh, and going to XDA forums, they will tell you to install a custom loader and firmware that is rooted, DON'T, I tried it on an RCA Viking II and it not only ruined it but it dragged the working of it down to a snails pace,,,, I would have to wait 10 minutes just for an app to open, and as for booting? It would take 15 minutes or longer just to boot from power on to the home screen, and then the battery would be eaten up, the battery would go from a full charge (100%) down to 70% during that boot, and as a result I had no choice but to put the tablet under a sledge hammer and went out and bought a Viking Pro, so NO! DON'T! use a custom ROM or any custom firmware, either use it as it is or dump it and pay out for a newer model (which is what the manufacturers want you to do in the first place).
