Upgrade to a Droid 4 From Droid 2 ?
Antman27
Member
Hello all so its about time for upgrade .. I THINK I want a Droid 4 (althow the Gf and daughter say Iphone)
Can anyone compare the Droid 2 and Droid 4 . Major complaint was bat life on the 2
Thanks for any thoghts
My wife upgraded from the OG Droid to the Droid 4 last month and has been really happy with it. The keyboard is a awesome and she says the display is fine, even in sunlight. I'd consider it for myself if the screen was a little bigger.
I got the D4 coming from a D Inc 2, and before that, an OG Droid. I love the QWERTY, screen size is perfect for me and the battery life is great when you combine it with Juice Defender or Smart Actions. Even without them, you would probably get a full day out of it if you don't use LTE too much.
Comparing to the Droid 2, the screen is a bit bigger obviously, and the blur is different. I have a friend that came from a D2 and he loves the D4. The build quality is much more thought out on this one compared to the D2.
Any other questions? Hope this helps.
