Carnotaurus
Most of you guys can probably wait for the Note 3 much easier then me because it unlikely that you guys have been using a 7 year old non smartphone since 06.
My brother in law is convincing me to buy the Note 2 once the Note 3 come out because it would be a few hundred dollars cheaper, but he bought his use which I would never do. This is going to be my first smart phone purchase (own a Iphone 3gs given to me by a friend) so it going to be a very special occasion for me. He also isn't gaming intensive on his phone like I would be doing so the higher spec and 1080 screen doesn't matter to him.
The decision is slightly harder for me because the Note 3 did not have the majority of things I was expecting. I thought the Note 3 would have the following: front facing speaker, 3500 mah battery, flexible screen, 16 megapixel camera with S-orb technology, 6 inch screen, and wireless charging.
Nonetheless it has something that the Note 2 (U.S) does not have, and that is 32gb, which is important for games and other apps.
So the question is should I get a Note 2 or Note 3? Will the air command be available to Note 2 user in later updates? Is $450 for Note 2 a better deal than $750 (tax) for a Note 3? Is all the processor and spec worth it on the Note 3 for that price?
Thanks
Thanks
