Upgraded to QuickOffice Pro
Corey Bryant
When I opened QuickOffice, I was given the option to upgrade to QuickOffice Pro for $14.99. I purchased this through the Android Market, hoping to keep everything in its place. However, I now have two applications - QuickOffice 4.0.120 and QuickOffice 3.3.49 (which wants me to register each time I accidentall start it).
How do I remove the QuickOffice 3.3.49 so I don't use it and so I can recoup that space? If, by the rare chance that cannot be done, how do I change the icon / name so I know it is the wrong one?
(Using Dell Streak 7 on the Android OS 2.2 and T-Mobile)
Thank you!
You remove it just like you remove any app. You can go to the Market, hit menu-my apps, then click that app and hit uninstall. Or you can go to menu-settings-applications-manage, find the app and hit uninstall.
Sorry I forgot to add / say that I had gone into the settings and it is not there. I have two applications listed (QuickOffice 4.0.120 and QuickOffice 3.3.49), but when I choose QuickOffice 3.3.49 - the option to uninstall is not there. I also downloaded an app uninstaller and QuickOffice 3.3.49 is not there to download either.
It seems that the pre-installed QuickOffice 3.3.39 is not able to be removed. Unfortunately, this seems to be a bit annoying to say the least.
I sent two emails to the company via the "Checkout". I finally received a response, telling me that if I needed support to go to support . quickoffice . net. I looked at their KB and saw one titled two icons, so it seems that if you upgrade, you will have two applications. A bit of a waste it seems.
