Root Upgraded.... whoops. Also: remap physical buttons?
terabyte128
So, yesterday, I upgraded my Breakout to the latest OTA update, thinking in vain that it may be Ice Cream Sandwich. It wasn't :mad: but now I can no longer get temporary root with zergRush. I get the message:
Code:
[-] Hellions with BLUE flames !
Any ideas on how to downgrade/restore back to the old firmware? Is it even possible? Or root with the new one? All I really want to do with root is to try and remap the annoying Nuance button to Google search or voice dialer. Any help is much appreciated.
Code:
Have you tried to access fastboot?
Yes I can still get into fastboot using: adb reboot bootloader
It shows the screen "ANDROID DEVELOPMENT MODE!!! FASTBOOT!!!"
That's the correct screen, right? :confused: I'm quite a n00b.
Yes that is right. You can use my all in one to install cwm recovery and then flash the super user files that i posted in there to gain root access.
