Hello
A friend has a Sony Xperia S lt26i. The original battery doesn't last long enough, to the point where wifi and GPS can only be used very shortly.
Google shows that it's indeed possible to replace it.
I have a couple of questions:
Thank you.
- How easy is it without technical experience?
- What bigger battery would you recommend?
Thank you.
