Help Upgrading problem
Hi,
I have 2.2.1 on my N1 and I'm trying to upgrade to Gingerbread.
I've downloaded, renamed and place the update.zip file on my sd root.
Once I try to install it I get the verification error message.
I have a Spanish Vodafone N1. I've read from Rusty that I should:
"You have a Vodafone Nexus One, if you want Gingerbread you have to root, install a custom recovery and flash through that."
Where can I find a step by step guide for that?
Rooting will erase all my contents, apps, photos, etc?
Any other risks?
Will I then get OTA updates or will I have to carry out future ones manually?
Is it worth it or should I just wait to get it from Vodafone?
Thanks!
