Try to get a class 6 card. Backup your old card to your computer. Format the new card in your phone, not on your computer, to get the proper file structure and basic folders created correctly. Transfer all the files from the backup to your new card. Only use your phone for the formatting of the new card. Do all the rest on your computer.
I did this when I went from the included class 2 card to a class 6 card so I could do HD video without dropping frames. I had no problems using the new card afterward.
Higher class rating than 6 won't buy you anything on this phone but won't hurt either. Class 6 is good enough for the 720p30 video this phone does. Be sure to read reviews on newegg - some cheap cards mislabel the class - the reviews usually point this out.Thanks.
Probably a dumb question - but higher class is better, right? Looking on newegg right now, and while I do see some class 6 cards, there's also some class 10 cards around the same price range as well.
Put the old card in an sd card reader on your computer.When you say backup, do you mean copy and paste the data?
