URGENT! Can't fix SU binaries via flash or flash TWRP?
How long did you hold down the power button? Your phone should power itself off when you hold it down long enough. It may take several seconds.
When Odin shows you that 'Pass' flag, you want to initiate a manually induced shutdown. You need to force your phone to turn off, you don't want to allow your phone any time to run through its normal shut down procedure (timing is important) -- that cursed recovery-from-boot.p script will run, replacing the TWRP Recovery you just implemented with the original Recovery.
Literally just tried holding it down for another minute and it hasn't done anything..
Yeah I've just checked and the 928F is the model that I have thanks, I'll give it a go and see if it works. Should I leave Auto Reboot on for this method?
Yes, leave Auto Reboot checked.
If it works and you get root, you can download a TWRP image file and use one of the flashing apps mentioned above from the Play Store to install it
So far so good I guess, it says it's going to bootloop a few times. I presume this is a normal thing? Hopefully rootchecker should say it's been rooted properly and fixed the damn binaries issue..
