Help Urgent Help for a beginner.
Hello Everyone
When i open the log on my Galaxy Ace, this message appears The application Phone (process com.sec.android.app.dialertab) has stopped unexpectedly. Please try again.
P.S. My device is not rooted
Please HELP.
Thanks
It looks like the dialertab app might be messed up. You can fix this by 'resetting the application '
Do this by going to settings > applications > manage applications. Then go to the 'all' tab. Scroll down and look for 'phone' click on it then click clear data. Pop out the battery, and put it back in then start the phone up again.
Hope this helps.
Hello Everyone
Please HELP.
Thanks
what happened with mine is something i installed changed the lcd density it needs to be 160dpi i dont know if you can change it with out root access. check the app store for a program the sets lcd density. read it to see if it is non-root unless you are rooted then lcd density modder works good
Hello guys am a new user, my samsung galaxy y s5360 dial tab gives a eror massage
The application phone ( process com.sec.android.app.dialtab) has stopped unexpectedly. and i also notice that most of the programes icon are not on the main manu and appear to be corrupted when seen on the MANAGE APPLICATION under settings.
please help meagently, thanks in advance.
