Root Urgent help!! Gt540 now lifeless!
iRhyiku
Following the instructions in the CM7 Thread, using the KDZUpdater
After attempting to update a friends optimus, the program crashed half-way through.
now the phone wont turn on, or do anything atall. It wont even vibrate when i hold down the power button.
Please HELP!
Plugging the phone in USB does nothing.. not even a acknolagement of any sorts from the computer. The phone doesnt show any signs of charging, and swapping the battery shows that the battery isnt empty
using CS_EMERGENCY or EMERGENCY or DIAG all say =PHONE NOT FOUND=
Please HELP!
Power Button + Volume Up button does anything?
mine phone is found,able to update thru cs emergency, but my phone wont power up.would only vibrate. please help me on this...please....thank you.
Download the KDZ again & make sure it downloads correctly, then reflash using cs_emergency... hope it works...
Try taking out the battery, SIM and memory card, then plug it in via USB, if it doesn't work then I reckon the motherboards dead. Just tell LG you we're trying to update to official 2.1 ;)
