Hi everyone, i am a user of s2 and i need help for the following:
1. My media volume when set to the max, it doesnt seem to be. Whenever i go over to the settings , volume and i shifted the media indicator, the volume goes to max all of a sudden. after which when i pressed cancel, it goes back to the same problem again. I have saw someone mentioned tt it may be a software glitch and a reset is needed so i did a reset last night but its still not solved.
2. i accidentally copied an image to the " clipboard" but i cant find the clipboard at all. where is it?
3. how do i shift an image to the folder i created? i cant move/copy.
4. android market for s2 right, any free app that i can dl to watch tv like pptv except tt data got charges. if my data is 12gb smartsurf 300, then when i dl eps will there be extra charges? any other apps related to recommend me?
I will greatly appreciate all your advices!! THANK YOU!
