avavinash
heres my code....i want to remove based on number and date and increse the count for each duplicate.....how to do it,....???
Java:
package com.example.call;
import java.text.SimpleDateFormat;
import java.util.ArrayList;
import java.util.Date;
import java.util.HashMap;
import android.app.ListActivity;
import android.content.Context;
import android.content.Intent;
import android.database.Cursor;
import android.os.Bundle;
import android.provider.CallLog;
import android.view.LayoutInflater;
import android.view.Menu;
import android.view.MenuInflater;
import android.view.MenuItem;
import android.view.View;
import android.view.ViewGroup;
import android.widget.ArrayAdapter;
import android.widget.TextView;
public class MainActivity extends ListActivity {
private ArrayList<String> conNames;
private ArrayList<String> conNumbers;
private ArrayList<String> conTime;
private ArrayList<String> conDate;
private ArrayList<String> conType;
int count;
@@override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
conNames = new ArrayList<String>();
conNumbers = new ArrayList<String>();
conTime = new ArrayList<String>();
conDate = new ArrayList<String>();
conType = new ArrayList<String>();
Cursor curLog = CallLogHelper.getAllCallLogs(getContentResolver());
setCallLogs(curLog);
setListAdapter(new MyAdapter(this, android.R.layout.simple_list_item_1,
R.id.tvNameMain, conNames));
private class MyAdapter extends ArrayAdapter<String> {
int count=0;
public MyAdapter(Context context, int count, int textViewResourceId,
ArrayList<String> conNames) {
super(context, count, textViewResourceId, conNames);
this.count=count;
@@override
public View getView(int position, View convertView, ViewGroup parent) {
View row = setList(position, parent);
return row;
private View setList(int position, ViewGroup parent) {
LayoutInflater inf = (LayoutInflater) getSystemService(Context.LAYOUT_INFLATER_SERVICE);
count=0;
View row = inf.inflate(R.layout.liststyle, parent, false);
TextView tvName = (TextView) row.findViewById(R.id.tvNameMain);
TextView tvNumber = (TextView) row.findViewById(R.id.tvNumberMain);
TextView tvTime = (TextView) row.findViewById(R.id.tvTime);
TextView tvDate = (TextView) row.findViewById(R.id.tvDate);
TextView tvType = (TextView) row.findViewById(R.id.tvType);
TextView cout = (TextView) row.findViewById(R.id.countout);
tvName.setText(conNames.get(position));
tvNumber.setText(conNumbers.get(position));
tvTime.setText("( " + conTime.get(position) + "sec )");
tvDate.setText(conDate.get(position));
tvType.setText("( " + conType.get(position) + " )");
cout.setText(" "+this.count);
count++;
return row;
private void setCallLogs(Cursor curLog) {
while (curLog.moveToNext()) {
String callNumber = curLog.getString(curLog
.getColumnIndex(android.provider.CallLog.Calls.NUMBER));
conNumbers.add(callNumber);
String callName = curLog
.getString(curLog
.getColumnIndex(android.provider.CallLog.Calls.CACHED_NAME));
if (callName == null) {
conNames.add("Unknown
} else
conNames.add(callName);
String callDate = curLog.getString(curLog
.getColumnIndex(android.provider.CallLog.Calls.DATE));
SimpleDateFormat formatter = new SimpleDateFormat(
"dd-MMM-yyyy HH:mm");
String dateString = formatter.format(new Date(Long
.parseLong(callDate)));
conDate.add(dateString);
String callType = curLog.getString(curLog
.getColumnIndex(android.provider.CallLog.Calls.TYPE));
if (callType.equals("1")) {
conType.add("Incoming
} else if (callType.equals("2")) {
conType.add("Outgoing
else
conType.add("Missed
String duration = curLog.getString(curLog
.getColumnIndex(android.provider.CallLog.Calls.DURATION));
conTime.add(duration);
import android.content.ContentResolver;
import android.content.ContentValues;
import android.net.Uri;
import android.util.Log;
public class CallLogHelper {
public static Cursor getAllCallLogs(ContentResolver cr) {
// reading all data in descending order according to DATE
String strOrder = android.provider.CallLog.Calls.DATE + " DESC";
Uri callUri = Uri.parse("content://call_log/calls
Cursor curCallLogs = cr.query(callUri, null, null, null, strOrder);
return curCallLogs;
public static void insertPlaceholderCall(ContentResolver contentResolver,
String name, String number) {
ContentValues values = new ContentValues();
values.put(CallLog.Calls.NUMBER, number);
values.put(CallLog.Calls.DATE, System.currentTimeMillis());
values.put(CallLog.Calls.DURATION, 0);
values.put(CallLog.Calls.TYPE, CallLog.Calls.OUTGOING_TYPE);
values.put(CallLog.Calls.NEW, 1);
values.put(CallLog.Calls.CACHED_NAME, name);
values.put(CallLog.Calls.CACHED_NUMBER_TYPE, 0);
values.put(CallLog.Calls.CACHED_NUMBER_LABEL, "");
Log.d("Call Log", "Inserting call log placeholder for " + number);
contentResolver.insert(CallLog.Calls.CONTENT_URI, values);
