Urgent Help Required (Rooting)
Hi Guys,
I am having a problem with rooting my G1, For the last hour I have been stuck at the point where I have downgraded the phone to the RC7 successfully and am trying to press enter twice and type the telnetd.
At this point I'm not sure if it should give me a sign that it has worked but I then goto telnet command prompt which is showing some questions marks them the # sign but when I type in the commands from the instructions the following happens: Typed exactly as it appears on my screen
mount -o rw,remount -t yaffs2 /dev/block/mtdblock3 /system
# #cd sdcard
# #flash_image recovery recovery.img
No such file or directory
# #flash_image recovery/sdcard/recovery.img
usage: flash_image partition file.img
# #cat recovery.img > /system/recovery.img
recovery.img: No such file or directory
Hi Guys,
# #cd sdcard
from you post it looks like you are Typing the "#" sign .... DO NOT ... the "#" sign is the command line prommpt ... you should just type the commands ...
Thanks for the reply I just needed to keep trying thats all but now I have rooted the phone does anyone have any advice as to what is the rom to use
