urgent help
Hi
I need urgent help! my samsung galaxy II screen froze, and i cant even answer phone calls. how do i un freeze the damn screen?
HI,
Pull the battery out. Put it back in and try to boot up. Sorry for your difficulty.
Steven
Hope you did what Steven mention, it should square you away, Welcome :ciao:,we are glad to have you, hope you enjoy the site.
Before performing a battery pull, I would try to hold down the power button for 8-10 seconds. See if that reboots your phone automatically.
I hope you get your device up and running.
Hi
Hi ecoalexandra... ;)
Welcome to Android Forums. I hope you have gotten this issue resolved. Something to remember with these type of smartphones (ones with removable batt): Whenever you are having problems -- removing and reinserting the battery should be one of the first troubleshooting steps to do. Nine(9) out of Ten(10) times, this method usually FIXES most problems.
