Root urgent pls help me!!
eboy
i rooted my spica and installed samdroid kitchen and turbo according to Beerkan's guide
but now it cant read my wma and mp3 files:mad::mad:
when i transfer the music files from my laptop to the phone, they become some funny numbered files residing in the LOST.DIR folder
sincere help appreciated:(
I would suggest formatting the SD card. You should have had to do this if you installed the Samdroid Apps2SD.
Backup what data you need, then reboot phone into recovery screen.
partition the SD card to whatever size you wish to use for Apps2D (max 1GB).
Then Format the 2nd partition.
Once that has been done, clear both the cache and the Dalvik Cache, and reboot the phone.
