Help USB and SD card problem
Hi, I'm using a n7000 Slimkat 4.4.4 rom, with slim kernel 3.0.80+ autobuild.
Previously I used link2sd to create a partition on my SD card to get more space on my internal, and after a while I realised my USB storage is being recognised as an SD card. I tried a full wipe and reinstalled my rom but now even the internal storage is messed up. Not even the reformat works anymore
It's too complicated to explain in words so here are the screenshots. So how f**ked am I and how do I salvage this?
Each time I link files into the card (700mb size, it worked previously) it freezes the whole phone
From the storage option I can see this:
1. Internal storage 2GB (normal, nothing wrong with it)
2. Internal storage 11GB (this should be USB storage, and it has a erase SD card option at the end)
3. SD card 2GB (It was 4GB but I used link2sd to create an internal partition. MTP and mass storage is not detected but using card reader it is fine)
4. USB storage (there is only a mount and erase SD card option which is greyed out/unclickable and does not has any space indicator)
http://dl-1.va.us.xda-developers.co....png?key=JlryghwuFXDZ0GC7ufeMCw&ts=1424859043
http://dl-1.va.us.xda-developers.co....png?key=1VGGxaEczwl_e7JbDN_pig&ts=1424859044
http://dl-1.va.us.xda-developers.co....png?key=Ho_wKR84U4H_fpK8T7J9ow&ts=1424859045
