I have tried to find an answer to this for a while now, but I have not been able to come up with it. For most of my android phones I have used a car dock with a power/usb cord that connects to a radio transmitter to play sound over my car speakers (yeah my truck is a bit older).
My current set up is from my S3. I have an iBolt S3 dock (which my n5 fits in perfectly) and I connect my s3 to the dock (there is a wire on the side of the dock, which has a port on the side where the usb power/radio adapter plugs into) I recall on my s3 I had to go into settings and pick external audio when connected to dock. I can not find this option in my n5 and when I plug in my n5 to the dock, the sound comes out of the n5 speakers instead of the truck stereo. (the n5 charges just fine)
The question is, is the option hidden somewhere to turn on the external audio, Is this dock only compatible as a dock for the s3, or is the n5 not able to put audio externally. I have stock software on the n5 btw.
Thanks in advance!
Thanks in advance!
