CzarMatt
Member
Hello,
Firstly, thanks to all the forum threads and wealth of informational posts - I wouldn't have been able to root with you guys as I am quite new to this sort of thing.
I used Unrevoked 3 to attain root and have flashed Baked Snack 1.7 onto my phone with Clockworkmod.
Everything seems to be well and good save for my phone is no longer detected by my computer. It will not accept a charge and will not detect as a removable disk.
I've updated to the latest WiMax update per instructions on Baked Snack's website.
Have I missed a step?
Thank you for your help and patience.
[Edit:] More information - when I plug the cable into my phone, the "Select which type of connection to use" box appears for a split second then diappears. The battery is not taking a charge nor is the phone detectable on my computer. I've installed the hboot drivers prior to using unrevoked 3.
