Help USB Connected message only when SD Card is inserted
varoescal
I having the USB Connected Message flashing on my notification bar only when the SD Card is inserted. I have tried removing the battery, master reset, SD card format... but message continue to pop up and I cannot connect my phone to the PC. My phone is a Samsung I5800.
Does anyone experience the same issue? Is there a known fix?
Thanks
Are you saying that you get the notification with the SD card inserted but the phone is NOT plugged into USB?
that's correct. The phone is not plugged but displays USB Connected only when the SD card is inserted in the slot. If I unmount the SD card, the message keep flashing, but if I remove the SD card and restart the phone. The message disappear. :confused:
Hi varoescal, I am facing same problem in my Samsung EPIC, Android GingerBoard. Did you find solution for this problem? If yes, Can you please share in this thread?
