I just started having a problem with my Indulge last night it will chime and tell me a USB connection has been made then it goes away then back etc... not only is this annoying if I am trying to do something because the pop up screen appears but I assume it will kill the battery(this is happening when nothing is connected)
I looked closely at the USB slot and everything appears normal....the center post isn't bent and nothing is stuck in there.. the USB cable connects smoothly and it still charges
anyone have this happen before and how did you fix it?
thanks in advance
thanks in advance
