Hello,
I have a Samsung Intercept and since I updated the system to Android 2.2 I could no longer transfer any files between my phone and windows vista. I connect the phone to the computer and then get the message to connect USB, I click the buton to connect and when I go to "My computer" the Removable Drive (F) appears but once I try to open the folder it says the folder is empty or to insert a disk.
I tried different times with the USB Debugging on and off. But the same happens every time. However when I plugged my phone to a Windows 7 it worked just fine.
Anyone have any idea on what should I do to have it working again?
I also have Samsung USB driver installed on my computer.
Thank you
Debora
Thank you
Debora
