Recently I am having a problem when I want to connect my Exhibit II to PC. I get this page after connecting the cable, and the phone memory drives never show up
It happens both in debugging and non-debugging modes.
I have no idea where this page comes from!!
Thanks
I believe that's the docking screen, it thinks you're plugging your phone into a dock (I think, I could be completely wrong)
BEFORE you plug your phone into the computer go into Menu>Settings>Wireless and network>USB utilities and select "Connect storage to PC". Then connect it to your PC, that SHOULD work.
Doesn't work correctly. This method does put two new removable drives on Explorer (I assume the phone and the sd card), but neither is accessible. Choose to open either one and it says to insert a disk in the removable drive.
There is something mysterious about the Samsung cable. I posted this in a rooting forum:
"To anyone having trouble getting the pc to recognize that the Samsung Exhibit II is connected:
Use only the Samsung data cable. A generic one won't work. I had the same problem using a usb data cable from an old LG on my Samsung. It would charge the battery but that was all. Once I switched to the Samsung cable that came with my phone, everything went fine. (Of course, you still need to install the Exhibit drivers; works with Exhibit II)
BTW, works fine on Mac with VMWare running Win XP."
