So I got my Galaxy Tab 7.7 last week and so far I have nothing but praise for the tablet. It's much easier and lighter to handle than my Acer A500 10" tablet plus the display screen is nothing sort of spectacular.
I did not try connecting the tablet to my desktop PC until yesterday. According to the manual, I can connect it directly without using Kies and so I did. After a while my PC recognize the device (GT-P6800) and I could browse both my brand-new 32 GB micro-SD card and the tablet's internal storage as well. As a test I copied a folder containing 8 music albums in mp3 format to a newly created 'Music' folder on the 32G card.
The copy process started but at the third album, it suddenly stopped and a message appeared on my desktop PC saying that the USB connection was no longer available! A message on the tablet also appeared to effect that the application MTP has stopped unexpectedly and tells me to try again. I still could see the tablet in Windows Explorer on the PC but if I try to access it, the same message appears. It was a weird experience! I removed the USB cable and retried the connection - this time it refused to connect. I then switched off the tablet and switched on again. This time I was successful in connecting the cable although Windows 7 displayed a message saying that the device driver was not successfully installed! I tried copying the rest of the files and again it suddenly disconnected with the same message as before.
Could anyone tell me what's going on? In the meantime, I am going to try to carry out the same process on another PC, failing which, I will try out Kies.
Well, I tried it out on another Windows 7 PC - sad to say, the same thing happened - USB connection between PC and tablet suddenly stops. The only difference is that the tablet hangs at the USB transfer screen (ie, the screen with a picture of a USB plug). I had to power off the tablet to recover back control. I also discovered after this incident that my music files is now listed twice for each song - one can be played without any problem and the other causes a message saying that the file is no longer there to appear! I had to go through each album and delete the 'cannot play' files - luckily I don't have too many music files at this stage. I still have not tried Kies as yet - this will be my next test.
