physicsguy
To anyone having trouble getting the pc to recognize that the Samsung Exhibit II is connected (for rooting, USB debug, data transfer, anything):
Use only the Samsung data cable. A generic one probably won't work. I had the problem using a usb data cable from an old LG on my Samsung. It would charge the battery but that was all. Once I switched to the Samsung cable that came with my phone, everything went fine. (Of course, you still need to install the Exhibit drivers for anything beyond USB mass storage usage; works with Exhibit II).
The LG cable worked fine with LG phone so I know the cable wasn't bad.
BTW, USB access and rooting work fine on Mac with VMWare running Win XP.
