AgentSmith80
I have seen people complain about this with other phones but not the D2G and the solutions others have found helpful have not worked for me.
Today I did a factory reset to my phone, the first since I've done since the gingerbread update. I attached my phone (via factory usb cable) to my laptop (Windows 7 32 bit). I immediately get a bubble saying "USB Device Not Recognized. One of the USB devices attached to this computer has malfunctioned, and windows does not recognize it". The phone does not charge, and the storage device does not show up on my computer. I tried rebooting the phone many times, rebooting the laptop, installing the driver from motorola, uninstalling and reinstalling the driver (several times), enabling/disabling "USB debugging" on the phone - which does bring up the option on the phone for "USB Connection" where you can select PC Mode, Media sync, mass storage, or charge only", I've tried switching between them but nothing changes, the computer still won't recognize that anything is attached.
I then tried plugging it into my high performance i7 PC with Windows 7 64 bit, same problem. I installed the motorola drivers there, same error, same behavior. Other USB devices work fine. So I know it is not an issue with the computers, it is with the phone.
I then did another factory reset on the phone and tried with the laptop again and same problem. I've tried pulling the sd card and reinserting. I've tried plugging into other usb ports. I've tried mounting and unmounting the sd card in the settings. Nothing changes.
Does anyone know a way to fix this? I would like to root my phone but since z4root does not work on gingerbread and I can not connect this thing to a computer, I'm stuck.
