Help Usb drivers for samsung moment syncing
I work for a cell phone company and most of the time when the prompt please install usb drivers, all it is is a setting on the device itself. To resolve this issue, here are the steps:
Home
Menu
Settings
Applications
Developments
Uncheck Usb Debugging.
Thank you so very much for this! one thing says to enable to do one thing then another says to disable for another!? well I sure do hope that the new OS improves all of that!
Thanks for this post! I was having great difficulty and was almost to the point where I was going to resign myself to taking out my SD card every time I wanted to get something from my PC! Now I don't have to!!! :D
USB debugging ON and OFF are two different modes for the phone to communicate with your computer. You will just need to remember which app/situation needs which mode.
Debugging usb doesn't work for me, only with it un checked can I connect to computers. Is there a way to fix this?
