richboyliang
I do usb mass storage and see two removable drives on my computer, MOT (G
and MOT (H
. Why are they divided into different parts? It seems that the contents of G are identical to the stuff shown when I use PC mode, but H is different stuff.
Are they BOTH stored on the SD card or does H represent the phone's internal memory? G is 16 gb and H is 8 gb, so it seems that H is internal, but that doesn't make sense since I moved many of my apps onto the SD card and those apps appear in H, android_secure. So which is which? If they're both SD, is there a way to access the phone's internal memory at all?
and MOT (H
. Why are they divided into different parts? It seems that the contents of G are identical to the stuff shown when I use PC mode, but H is different stuff.Are they BOTH stored on the SD card or does H represent the phone's internal memory? G is 16 gb and H is 8 gb, so it seems that H is internal, but that doesn't make sense since I moved many of my apps onto the SD card and those apps appear in H, android_secure. So which is which? If they're both SD, is there a way to access the phone's internal memory at all?
