Root USB Mountin
draelee
ok I got an issue I justnoticed. I had finally achieved root!!!! yayyy :)
but when I plug my usb up I can't mount it. I was wondering if there was something i needed to do or something I am not seeing, because I don't see the usb symbol pop up in the notifications when I plug it in. thanx any help is appreciated
not sure what actually caused it but I decided to just try and reboot the phone and then rehook it up and that seemed to have fixed it. so now i can mount with no problem.
Yup, same problem. Occasionally, when I plug in the USB cord, it will not give you the option to mount the flash card. A reboot fixes the problem but it's still annoying.
I've found that if I have USB Debug checked, I can't mount USB. As soon as I uncheck it, the USB icon pops back up. Sprint flash tool works fine. I am unable to adb shell in though.
