Hello, new here, and cant seem to find anything relevant on the interwebs... My Pixel 2xl is pretty darn good.
I recently decided to try a USB Network adapter, and I have success when i am on a network with DHCP. Just turn off WiFi and Date and im good. This is great for tuning Speed Tests, which i do often with my work.
Now the twist... I want to be able to use it to configure Ip Cameras, basically hook the POE and the camera to the phone. This is the order:
Pixel ---> POE---> Camera. This is typically done with a PC or Laptop, bot of which I prefer not to carry all the time. I would easily be able to adjust IP settings with these. Now with the phone, this would be a rather quick and easy thing, but I cannot seem to find a way to set the IP, only WiFi allows this, and that is not going to work.
Has anyone ever been able to change the IP via usb?
Current Service is Straight Talk, a flavor of TracFone that uses Verizon towers. Its got limitations, but does not hurt the pocket. I save $100 a month by shopping at Wal*Mart essentially. Could this be the issue?
