USB no longer dectected
Wemperer
I recently rooted my Motorola Triumph and its working fine however, I can no longer USB connect to my laptop. I've tried with USB debugging on and off and the card is readable by the phone but it just wont connect anymore.
I'm guessing it may have something to do with installing ASTRO file manager? I uninstalled it but still no dice. Any ideas?
The phone does charge via usb tho.
I had a similar problem after I flashed an unroot kernel to my Droid Charge. I posted on here for help. Turned out I had to flash a file, root_dismount_usb_sdcard_fix (1), to correct the problem. Do not know if it will work for you, but here is link to my thread. The answer is in post 4. Just click the link and it will take you the the page. There may be a similar type page for your phone.
http://androidforums.com/samsung-droid-charge/474365-computer-does-not-see-sd-card-help.html
